I know this may seem like such a silly question, but I have had the darnest time finding info tell me exactly how much oil to use during routine oil change including filter. My engine has the original oil pan. I assume 5 quartz but would like to know for sure. Thanks, Craig #36551
1961 Oil Quanity
Re: 1961 Oil Quanity
Dale,
As always I appreciate a somewhat round about post, but as for the Owner's Manual I found no reference to a total amount. On page 22 it references when and how often, but unless I am totally blind I found no other reference. Thanks
As for the AIM, I will check it now. Cheers, Craig- Top
Dale;
I found this easy to do when I had an adapter and screw-on oil filter. However, when I went back to the original oil filter canister, I was unable to fill it without the oil leaking down my arm while tighten the canister bolt down. Whats the secret?- Top
jon----
What's the secret? Stick with or go back to the spin-on oil filter conversion. GM didn't go to this system in 1968 because the cannister-style system worked just as well. You can get all of the benefits for your C1 or C2 by going with the conversion. Just before you have the car judged, you can switch to the cannister (it's VERY easy, of course). Then, when the judging is over, go back to the spin-on at the first oil change.In Appreciation of John Hinckley- Top
Hi! Craig
When I first purchased my 61 I sent to GM for an informational package and they sent me a 1961 specification booklet free. Information provided: Five quart oil pan less filter.
Hope this helps!
Ray #36314Ray Carney
1961 Sateen Silver 270-HP
1961 Fawn Beige 315-HP- Top
