Back in early Sept. (approx. 9th) I posted some questions about some cooling problems I was having with the L-72 in my car. Duke Williams sugested a five step process, in which I've completed most, but still have some questions.
I have since connected the vacuum line from the vacuum can to the other vacuum line on the carb (non-ported side) and now have vacuum at the vacuum can at idle. This has resulted in excelent idle and response. Some how I fell I still don't have enough vacuum. (see details below)
Now the questions. Would I have more vacuum by installing an adapter in the manifold plug direct vs: tapping into the existing vacuum line on the carb?
I have not changed the can as of yet, (as recommended) but would like to know does this NAPA one (Echlin/NAPA # VC1810) have lighter springs to give more advance than what I have now? (I don't know which vacuum can I have on the car now, but I assume it is the correct replacement for the L-72.)
Here is the current readings from my car:
Test # 1 - Hooked to ported vacuum
Base timming 6 @ 850RPM (no vacuum at can when hooked to ported vacuum)
8 @ 1000 RPM
17 @ 1500 RPM
37 @ 2000 RPM
45 @ 2500 RPM
Test # 2 - Mechaincal advance only, vacuum line disconnected.
7 @ 1000 RPM
17 @ 1500 RPM
24 @ 2000 RPM
30 @ 2500 RPM
Test # 3 - Vacuum advance only.
5" = 6 = base timing
8" = 12 - 6 (base timing) =6
10" = 18 - 6 = 12
15" =26 - 6 = 20
And the last question, the factory calls for timimg of 8 degrees BTDC. Is this a good starting base?
As usual thank you for your help.
8 @ 1000 RPM
17 @ 1500 RPM
37 @ 2000 RPM
45 @ 2500 RPM
7 @ 1000 RPM
17 @ 1500 RPM
24 @ 2000 RPM
30 @ 2500 RPM
10" = 18 - 6 = 12
15" =26 - 6 = 20
