'67 Power Brake Booster Identification & Rebuild - NCRS Discussion Boards
  • Craig Jewett
    This winter I plan to replace my master cylinder with a "DC" original that I picked up and had rebuilt by Stainless Steel Brake. (They did an awesome job) I also plan to remove the booster assembly and have it re-plated with that gold-green zinc dichromate finish. I am assuming this is the correct finish.
    Is it easy to disassemble and rebuild a booster ? Can you buy parts for it ?Also, how can you identify the booster assembly as an original part ? I do not see any numbers on the unit.
    Thanks in advance.
    Craig Jewett NCRS #28049 '67 L-79 A/C coupe.
