CORVETTE MANUAL / FAST STEERING - NCRS Discussion Boards
  • Myron D.
    • August 31, 2003
    • 33
    HI, I HAVE TWO QUESTIONS, THE FIRST IS; I HAVE A 1959 CORVETTE ASSEMBLY MANUAL FROM CORVETTE AMERICA, IS THIS A DIFFERENT MANUAL FROM THE AIM I HERE SO MUCH ABOUT? THE NEXT IS I FOUND THE ORIGINAL OWNER OF THIS CAR AND THEY SENT ME A FAST STEERING ADAPTER W/STUD KIT, HOW IS THIS MOUNTED? THANKS SCOTT
  • Dale Pearman
    Re: CORVETTE MANUAL / FAST STEERING
    This adapter bolts around the third arm. The tie rod ends go into the adapter plate instead of the third arm. The "U" clamp goes around the arm. It's impossible to install this part incorrectly.
    If It's a reproduction it won't work! Use only an original fast steering adapter.
    Also what do you hope to accomplish with this installation?
    Dale Pearman
    • Myron D.
      • August 31, 2003
      • 33
      Hi, I believe this to be original part for car.I want to put car back to it's original condition. Would it change the steering ratio? thanks scott
      • James F.
        • December 1, 1985
        • 596
        Dale,
        Please be specific on "if it's a repro it won't work." Educate me (and the rest of us) on what's not to work? Possibly he wants less wheel turn per wheel turn. I've had a quick steer on my Corvette since 1960, wouldn't have it anyother way! Regards,
        • Dale Pearman
          The geometery is incorect on the reproduction piece.
          I run a QSA as well. Even with 2.25 x 15 tires! Just want to know if people are doing things with an objective in mind. Some times it helps to think about what yor goals are before adding parts. This car evidently has the HD Brake and steering option!
          Dale.
