IR Gun - NCRS Discussion Boards
IR Gun
+ More Options
Posts
  • John Lokay
    IR Gun
    I recently purchased an IR gun and would like to know where is the best place on the engine to take and obtain an accurate temperature reading. Should I aim the gun at the thermostat housing, temperature sending unit, intake manifold area below the temperature sender? Thanks
  • John M.
    • January 1, 1999
    • 1553
    Re: IR Gun
    John, I allways shoot the thermostat housing. A word of advice, even though the Ir gun may have a laser sighting device on it, that does not indicate what it is taking the temperature of. The guns take an average reading of a constantly expanding cone-shaped pattern. The closer you get the gun to the area measured the more accurate the reading will be. I have technicians working for me who were trying to read the temp of an electrical termination from across the room!
    Regards, John McGraw
    • Ed Jennings
      Re: IR Gun
      I have found I get teh most consistant readings at the water passage in the intake just at the base of the thermostat. As John points out, the closer the better.
      • Bob Herman
        Re: IR Gun
        I'm looking into buying an IR gun. Where did you guys find yours? What manufacturers make quality guns?
          Re: IR Gun
          I've had a Raytek MT-4 for several years - terrific diagnostic tool; most places sell them for $99.95, but check out the link below for $59.95.
          3dCool Site - Raytek MT-4 I.R. Gun
          • Bob Herman
            Thanks John! *NM*
            • Mike G.
              • April 30, 2001
              • 180
              Thanks, John! I placed an order! *NM*
              • Al Corelli
                Re: Thanks, John! I placed an order!
                Me too!!
                Thanks John.
                AC
