61 Engine Pad Help - NCRS Discussion Boards
61 Engine Pad Help
  • Dave S.
    • August 31, 1992
    • 2926
    61 Engine Pad Help
    I need some help in clarifying the VIN portion of the pad stamp on a January built 61. It is VIN #46XX. What would be the full stamp on this motor???? Any help is appreciated.
  • Robert L.
    • April 30, 1979
    • 97
    Re: 61 Engine Pad Help
    Dave,
    I have a 3756519 motor in the garage with the following:
    Casting date: A191
    Stamp pad 1106049 F0215GS
    Hope this helps.
    Bob Lemke
    MCMLVII
    • Dave S.
      • August 31, 1992
      • 2926
      Bob, Thanks for the info. This car is VIN 1104587 and the Cars VIN is 04587. The first 1 is for 1961, what does the second 1 represent????
        Dave -
        The first "1" represents the 1961 model year, and the second "1" is the first digit of the six-digit car VIN number; even though it's only the 4587th car built, the VIN is always six digits, and in 1961 all Corvette VINs started with "1", thus the full VIN is 104587.
        • Dave S.
          • August 31, 1992
          • 2926
          Thanks, John, It seems the pad in question is fully correct.
          • Dale Pearman
            The FULL Vin Is
            10867S106049. "1" the model year, "0" a spacer digit, "687" the RPO for Corvette, "S" for St. Louis, "1" a spacer digit and "06049" the sequence or serial number.
            1961-62 VIN "DERIVITAVES", stamped on the engine pad as well as transmissions in 1962 only, is a SEVEN digit numeric. 1106049 would represent "1" model year, "1" a spacer digit and "06049" the sequence or serial number.
            Vin derivatives started in December of 1959 for the 1960 model production and at first were SIX digits.
            Dale Pearman
