Over the weekend I was able to get a reading on my oil pressure to check what I suspected was a bad gauge - it was showing a max of 15 pounds. The test gauge read a max of 40 so I am pretty relaxed right now... BUT.....
I wasn't relaxed when trying to get off the oil pressure fitting on the back of the block. I removed the PCV tube and the ignition shield mount and unscrewed and carefully moved the oil purssure tube. I was not able to get the fitting off.
Cant put a socket on it - it almost butted up against the intake manifold. Can't put a wrench on it - as you try to turn it the wrench hits inte intake and slides off. I was starting to destroy it so I stopped and put everything back together. I'm small enough to get under the dash and attached a pressure gauge at that point.
Anyone know how to get that fitting off?
