C3 Temp Guage Calibration - NCRS Discussion Boards
  • Jim R.
    • November 1, 1999
    • 47
    I've seen a few messages on this topic, but now I have some hard numbers to deal with.
    I put a new radiator core in my '69 350/300 along with a 180 deg. thermostat and a new temperature sender. I also installed all new foam seal around the radiator. I got the temp unit, M112B from ZIP with a new pigtail (wire and clip). When driving, the temp guage has been showing between 212 and 225 deg. F consistently, depending on the outside temperature for some time.
    Today, I clamped an A/C type thermometer (metal stem with a button dial) on the side of the top radiator hose next to the thermostst housing. The outside air temperature was in the low 70's. I drove the car for over an hour and it showed a steady reading -- did not move. The guage goes from 210 to 250 with only one hash mark in between, so I'm guessing it was reading about 212-215 deg. F.
    I stopped the car with the engine running and popped the hood. The thermometer read 172 deg. F. I continued to drive the car and when I stopped and shut it off, the temp guage read about 205-208 deg. F and the thermometer read 175 deg. F.
    Temp Guage Thermometer
    at idle 212-215 172
    stopped 205-208 175
    Can anyone tell me if these temperatures make sense and how to correct the guage reading. I've heard you can put a resistor in-line from the temp sender, but how do you know how many ohms???
    Jim #33086
  • Ed Jennings
    Re: C3 Temp Guage Calibration
    Check the resistance of the temp sender with a digital ohmmeter. A room temp, it should read about 700 ohms. The current crop of GM senders are improperly calibrated. There is someone (or maybe several people) who can recalibrate the senders. Alternately, you can go to Autozone and buy a Wells TU5 sender for $6 and probably get a proper reaading. Installing a resistor in the line will get you a correct reading at one point in the scale, but it will be inaccurate in all other ranges.
    • John D.
      • August 31, 2001
      • 280
      Hi Jim:
      My 68 also reads consistently high. I just got a NOS temp sender (1513321) and will be trying that.
      I noticed a calibration service for gauges and sending units listed at the following website. I cannot give you any info on the service.
      Good luck, John
