1965 Window Regulator Rebuild - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    The driver's side window regulator (non power) needs a rebuild, but before I dismantle the door and put the car OOS, I would first like to do some homework. The problem is, that the window does not stay fully closed, and usually slides down about 1/2". I can also fully open and close the window by pushing the glass up or down (of course, the crank spins while I am doing this). I have previously replaced any broken rollers for the track mechanism. I inspected the sector gear prior to installation, and all teeth are in place, and look healthy.
    I would like to rebuild the unit, but would like to get an idea of what part(s) I will need. I also would like to know where I can get them.
    Thanks in advance.
    Joe
