C3 73 BB Valve Covers - NCRS Discussion Boards
  • George W.
    • November 1, 1993
    • 68
    I am looking for information (descriptions,reference material,pictures) that would show me the difference between 73 Vette BB valve covers and other BB valve covers. I have a set (did not come with my car) that are painted,no drippers,with one tall (at rear)and one short (at mid point)Plug wire holders on each. There is a PCV valve on the driver side cover along with two bend over wire clips on the intake side of the cover.(These are located about 1/3 and 2/3 along the length of the cover) The right side cover has a rubber oil fill plug in the center and a crankcase breather connected to the air cleaner. Any help with locating this information will be greatly appreciated.
    • 43221
    Re: C3 73 BB Valve Covers
    George-----
    There were a large number of valve cover configurations used on Chevrolet big block engines during the 65-74 period. Your valve covers are definitely the 71-74 style covers inasmuch as they use the rubber oil fill plug. However, I don't think that they are the exact Corvette configuration. All Corvette big blocks from 1972 to 1974 used the same covers. The 72-74 Corvette valve covers did have the wire clips on the intake manifold side of the cover and, as I recall, did not have drippers. However, as I recall, the 72-74 Corvette big block configuration did not use the tall rear spark plug wire retainer "tower". I also believe that the Corvette valve covers had individual spark plug wire guides spot-welded to the exhaust manifold side of the covers. Although I could be incorrect on this point, my recollection is that they are 4 "L-shaped" brackets with a "cutout" for the plug wire.
    Although I am certain that the covers that you have are from the 71-74 period, they may be a slight variation used on some other Chevrolet chassis. Of course, I could be incorrect about the rear "tall tower" and the individual spark plug wires clips. But, that's my recollection.
    • Donald S.
      • August 31, 1996
      • 186
      George,
      You may want to check out the Cranes Corvette web site. They reproduce the big block valve covers and have some basic descriptions of the different variations. http://www.cranescorvette.com/427_valve_covers.htm
      Don Smith #28087
