1961 BRAKE DRUMS - NCRS Discussion Boards
1961 BRAKE DRUMS
  • Joe D.
    • April 30, 2002
    • 382
    1961 BRAKE DRUMS
    Does anyone know the part number of the brake drums for a 1961? Should it be stamped on the drum? Thanks, Joe #37862
    • 43240
    Re: 1961 BRAKE DRUMS
    Joe-----
    The original PART number for 1961 Corvette brake drums, front and rear, was GM #3752622. I don't think that this number was cast anywhere on the drums. However, another CASTING number may have been. If so, I don't know what it is.
      • 15696
      The two original rear drums from my SWC have different casting numbers - 3752623 and 3828688. The '63 rear drums are the same as the solid axle front and rear drums, except HD brakes.
      There appears to be several casting numbers that were used over time. If your castings have the max diameter stamped or molded into the material, they are post '68 OTC replacements.
      • Joe Pennington
        I have a pair of original rear drums with the original flat wire springs that are stamped 3752623.
        • Dale Pearman
          All my used C1 drums as well as NOS (in black and yellow boxes) show the same part number BUT it's NOT stamped. It's cast debossed.
          Dale Pearman
            • 15696
            I agreed. The casting number is indented and part of the casting mold.
            Do you have both the 623 and 688? Know why there are two? Any other casting numbers for the 11x2 drums.
            One other question: Do you have any 63-64 2.5" drums and what casting numbers are they.
              • 43240
              Duke----
              GM #3828688 is a later CASTING number first used, I believe, for 1963. However, functionally, it is interchangeable with the earlier castings. 63 models could have either casting. However, the 61 could not have originally used the 3828688 casting.
                • 15696
                Any idea why they would have two different casting numbers in production at the same time. I really can't tell any difference between them. Was one perhaps made by a different vendor?
                • Dale Pearman
                  I have an NOS 2 1/2 Corvette front drum (63-65) on eBay right now. Part #
                  3830116. ebay 1860321077.
                  Dale.
                  • Dale Pearman
                    The casting configuration was changed. A cast circumferential recess was still present for the anti-chatter spring but the "U" groove, in which the backing plate cirfumference rides, was eliminated. All the NORS drums use this latter configuration and are quite obvious to the experienced judge. During production, an NOS, correctly configured drum WAS available in a yellow and black box. In the seventies the design was changed. I suppose because the lip on the drum was fragile and subject to damage when roughly handled. All the NORS pieces were made in Canada with the latter part number.
                    Today's "reproduction" drums have neither the lip for the "U" groove nor a recess for the anti-chatter spring. One gentleman in the hobby machines a groove for this spring withour regard for the material thickness of the drum thereby creating a brake drum with MUCH less strength than original. In my opinion they are dangerous.
                    Dale.
