1957-60 balancer and pulley - NCRS Discussion Boards
  • Jason Upshaw
    Hi everyone,
    I have a riveted balancer/pulley that I believe came off of a '57 283. Are the dimensions the same for this combination as the '60 Corvette 283 balancer with bolt on pulley? I am trying to see if I can use the riveted on my '60 or if I will have to buy the balancer and pulley seperately. Thanks in advance, Jason
  • Joe Pennington
    Re: 1957-60 balancer and pulley
    Jason, I can't answer your question on the 60 dims, but my 56 crank pulley is 6 & 3/4 inch diameter. I know it dosen't relate to your question but what is the diameter of your generator pulley? I think mine might be the too small at 3 & 5/16. thanks,
    Joe
    • Dale Pearman
      Is your 1960 a solid lifter car?
      Dale.
      • James F.
        • December 1, 1985
        • 596
        Re: 1957-60 balancer and pulley- Joe
        Joe,
        Your '56 generator pulley should measure 3 3/8" diameter. Your's sounds close and correct. Regards,
        • Calvin M.
          • August 31, 2000
          • 117
          Hi Jason -
          Just fyi, the 57 JG indicates that the 283 HP engine used a bolt-on pulley, not the riveted version, so yours is probably from a base, 245, or 250 HP engine. Most 270's were also apparently riveted. (Mine is.)
