Went to check my headlights on my 72 BB coupe yesterday, and the low beams were fine, but when I stepped on the high beam switch the low beam on the passenger side went out. Any thoughts ? Thanks in advance, Ray
hi beam-lo beam
Re: hi beam-lo beam PS
Ray,
When you switched from low to high beams and the low beam went out, it should, but the high beam filament should have lit up. Since it didn't, it is most likely broken and the only fix is to replace.
DonThe light at the end of the tunnel has been turned off.- Top
Re: hi beam-lo beam
Also make sure it's not just a bad connection. I had the same symptoms and changed the bulb to a tested known good one only to have the same thing happen. Once I sanded down the connections inside the wiring end both bulbs worked just fine. ~Juliet
1970 Corvette Registry2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
1965 Coupe (Greg's project No Flight)
Gone but not forgotten:
1987 Yellow Convertible 199k mi.
2002 Yellow Convertible 100k mi.
2007 Atomic Orange Coupe 140k mi. RIP flood 2015
2007 Lemans Blue 6-Spd Coupe 34k mi.- Top
