holley question - NCRS Discussion Boards
holley question
  • Werner R.
    • March 3, 2008
    • 184
    holley question
    i took the shooter off of my 3310-3. i did NOT see a steel ball at the bottom of the threaded shaft. isn't there supposed to be one? if mine is mmissing, is it worth putting one in? will my car run rich without it?? will there be erratic filling of the pump chamber without it??
    werner
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: holley question
    there should be a solid cylinder with one end pointed in the pump shooter well.. if you can not find one i can send you one. clem
    • Werner R.
      • March 3, 2008
      • 184
      Re: holley question
      hey clem
      thanks for the info. i will look for this cylinder and if i don't find one, i will get back to you. thanks again.
      werner
