Vacuum Lines - 71 vette - NCRS Discussion Boards
  • Peter B.
    • July 31, 2000
    • 155
    I am replacing all my vacuum lines on my 71 Vette. When replacing the lines that run to the headlights, I noticed an extra two lines (thin ones) that were cut and not in use.
    Any Ideas of what they are?
  • Paul E. Young
    Re: Vacuum Lines - 71 vette
    Peter, They are lines that were used for headlight washers in earlier sharks that were discontinued in the 1971 year. Paul
      • 11644
      They should have a red stripe on them if they're the original headlight washer lines. I purchased the reproduction lines and cut them to match the originals even though I have no washers (late 71 car).
      Any reason you're replacing all your lines?
      Patrick
      • Peter B.
        • July 31, 2000
        • 155
        Hi - thanks for the help.
        I am replacing the lines because I have some vacuum leaks. Instead of finding the problem, I thought it would be a good time to replace them all with oroginal looking ones.
        You say you have a 71 vette, did you restore it? If so, do you mind if I keep your e-mail handy to bounce ideas off of you from time to time?
        Regards
          • 11644
          Peter,
          No problem.
          Send me a note now if you're interested in some vacuum tips and others.
          Patrick
          • Peter B.
            • July 31, 2000
            • 155
            Thanks Patrick,
            I saved your e-mail. I will be getting in touch. I am doing quite a few things on my vette and a voice of experience is always worth alot.
