C1 BRAKE HOSE - NCRS Discussion Boards
C1 BRAKE HOSE
  • Joe D.
    • April 30, 2002
    • 382
    C1 BRAKE HOSE
    I bought 4 brake hoses for my 1961. They are much smaller in diamiter then the old ones. Are all the replacement brake hoses like that? Thanks, Joe
  • Mike E.
    • February 28, 1975
    • 5139
    Re: C1 BRAKE HOSE
    No--GM ones from the past, and Bumper to Bumper stores at the present, among others, are the right outside diameter.
    • Steve Junkersfeld
      Re: C1 BRAKE HOSE
      Joe,
      I suspect that my 56 is the same brake layout as your 62, and so, you should only have 3 hoses - one goes from the junction block to each front wheel cylinder and the third goes from the rear of the long brake line that extends down the frame to a junction block on the rear end housing. The replacement hoses I bought were dimensionally the same as the original ones. It sounds like you have the wrong hoses. Good Luck Steve
