What is the name of the tool that is required to remove the bolts holding the grab bar in place? Are there any other similar bolts on the car which require the same tool? Thanks.
C1 Tool Name
Tags: None
- Top
Re: C1 Tool Name
Another source for these bits may be your local Home Improvement Supply Store. Locally a Black and Decker 1/4"hex drive bit is available in both 5/32" and 3/16" sizes. They are described on the blister card as "Clutch Screwdriver Bit Tip". Part #'s are 71-368 for 5/32" and 71-369 for the 3/16". Chase Pitkin ( a regional DYI Store) carries them in the drill bit display area. The advantage of the bit is that it can be driven with a number of different tools depending on the space available.My $.02- Top
