Gas tank? - NCRS Discussion Boards
Gas tank?
  • Mike Shouppe
    Gas tank?
    I have a 75 corvette, and I need to replace the sending unit in the gas tank. The only problem is, I can't figure out how to get the tank down to work on it. I know the sending unit is on the top of the tank, but how do I get it down without breaking anything? thanks...also, It's a stingray and on the driver's side (right in front of the "Stingray" emblem) is a hole. What is supposed to go there? I have no idea.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Gas tank?
    In 74 the alarm activator switch was moved to the drivers side front fender by the emblem.
      Re: Gas tank?
      Mike -
      The spare tire carrier and most of the rear exhaust hardware has to come off in order to drop the tank; the procedure is outlined in the Chassis Service Manual.
        • 43221
        Re: Gas tank?
        Mike-----
        Have you procurred a new sending unit yet? This item, last available under GM #25000316, has been discontinued for quite some time. NOS examples are difficult to find. However, the last time I checked, I believe that Dr. Rebuild still had some NOS units available. They're not cheap, though. In fact, they were not cheap when they were still available from GM.
