Should the Fuel Pump push rod be changed with cam - NCRS Discussion Boards
  • Scott Marzahl
    When replacing the cam and lifters, should the fuel pump push rod also be changed, after all it is essentially a lifter. Just curious.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Should the Fuel Pump push rod be changed with
    if the end are smooth and it rolls straight on a flat smooth surface reuse it.
