Where does the rear harness (from Lectric Limited) join the dash harness (also from Lectric Limited)? I traced the old rear harness to an area near the antenna - and that was as far as I could feel or see.
'66 rear harness
Re: '66 rear harness
Chip, My mistake - Left side (driver's side) take off kick panel & sill plate, pull carpet back and you then can remove the metal wire cover. That will expose the wires you are trying to get to. Be careful with your carpet behind the seats. If it is original it can be fragile.- Top
From where you have traced the harness (near the antenna) it enters the interior through a grommet in the rear bulkhead and then runs over the arch of the wheelwell and then down to the floor where it runs along the driver's side as described by other respondents, under a metal cover.- Top
