where can I get the OEM paint for my 71?
frame paint
Re: frame paint
I don't know if they make that anymore but it was so bad that even gasoline would wash it off. I used black International "Interthane" with a hardener that was supplied as A and B and used a urethane flatener that you mix by volume (40% is flat flat) and it came out great. I used 25% flatener (by volume) on the frame and used the paint with only 10% on the A-arms and brackets. David- Top
Re: frame paint
I painted my '63 frame with PPG DP-90, a two part black primer. I then painted it with some of the Quanta paint which is supposed to be the same as the original paint used. Where do you live? I've got enough left over to do at least two more frames.- Top
