I have not removed this from the car so somethings might be more clear when I do.
But for now, How many diaphrams are inside an actuator?
If I have one that will not go up, but will go down. Same actuator will go up if I send air pressure into the backside port (instead of vacuum). This obviosly means that one (or only) diaphram inside is good.
I see people selling seal kits and boots for actuators. Is this whats bad for the unit that won't come up.
All testing proves the the actuator relays work as they should. But the vacuum can does not seem to have check valves as the service manual indicates it should. Are there really check valves at the can?
Thanks for the help
Thanks for the help
