C2 1967 Frame numbers - NCRS Discussion Boards
  • Stephen L.
    • May 31, 1984
    • 3158
    I am in the process of restoring my frame. Prior to dipping/chemically stripping, I could not make out the frame number as it had been painted over.....
    After stripping, the number appeared as a slightly different "etch" in the metal and could be made out using a "shadow" light.
    Problem: The number is a stencil that was correctly applied upside down, but the numbers are reversed as follows:
    303196-33-PC
    3900200-4-7/GC
    The restoration guides I've found indicate that the frame number should be as follows:
    3900200-3(x) [x=1-4] {no "PC"}
    303196-(m)-(d)/GC [m=month] [d=day]
    The VIN serial number 15770 indicates an April assy
    The tank sticker indicates an April 14 expected production date.
    Should I replace the number as I found it and face potential judging issues or should I replace the number as restoration guidelines indicate? I tried to photograph the number but it is extremely difficult to get a good legible photo. This is the first time the body has been off the frame....
    Thanks for any input
    Steve
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 1967 Frame numbers
    Steve, If you don't replace the numbers as they were originally then it would not fall under the term restored. If you just follow the book and not what the car was, then it is a restification. I believe the car. My 67 was (upside down)3900200-33 303196-GC-214 as best I could make out, so that's what I put back on it.
    • Dick C.
      Past NCRS President
      • November 1, 1995
      • 453
      Anyone have original stencil photos for early 67 cars
      Dick Capello
      New England Chapter/Mid Atlantic Chapter
      Past NCRS President
      Past Region 1 Director
      • Stephen L.
        • May 31, 1984
        • 3158
        I found some stencil photos in a restoration guide by Joe Tripoli.
        I have also taken some photos of my own frame numbers (hard to discern) that you are welcome too.....send me an e-mail
        Steve
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          Leave it the way you found it! My April 10th car..
          is original, with the numbers like yours (Reverse of those in Tripoli's book.)
          This is not uncommon.
          H.a.N.D.
