The driver's side stamped steel valve cover used on base motor cars in 1972 has two wire clips spot welded to the inside edge. These wire clips are partially coated with a vinyl-like coating. The coating on the cover that I have is black, with no evidence of chevy orange paint. Other people have reported that the coating on their covers is painted chevy orange. What is correct?
Anybody know what the "assembly" process was for these valve covers. Perhaps something like:
1. Lower part of wire clip is partially coated with vinyl-like substance.
2. Upper part of wire clip is spot welded to unpainted valve cover.
3. Unpainted valve cover is installed on engine.
4. Entire engine is painted chevy orange, which would also include the vinyl-coated part of the wire clip.
I suspect that paint did not stick well to the vinyl coated part of the wire clip, which would explain why my clips have no paint on them.
Anybody have any thoughts or additional info on this subject?
FYI: I also understand that 1971 base motor valve covers only had one wire clip on the driver's side valve cover. Since 1971 / 1972 were the only years that used a push in rubber oil plug (in place of a twist in oil cap), that would make the 1971 driver's side cover unique, as well as the 1972 driver's side valve cover unique (Is this sentence complicated enough?).
Does all of this sound right? Anyone have conflicting information on the subject. There might be enough info here for a Restorer article.
