Where to buy heat treated ,fine thread bolt and nu - NCRS Discussion Boards
  • Eric Fairclough
    Does anyone know where to get fine thread heat treated suspension bolts and nuts.( in general ) The auto parts stores hardly carry any and the hardware stores only have coarse thread. Thanks Eric
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Where to buy heat treated ,fine thread bolt an
    the larger builder suppliers like lowes,home depot have grade 5 and grade 8 fine thread bolt and nuts.
    • Gerry Proctor
      If you know the sizes you need, you can get a real quality fastner from ARP. Here's the bulk bolt application guide: http://www.arp-bolts.com/media/pdf_f...f_stanchro.pdf
        • 43260
        Eric-----
        Orchard Supply Hardware (OSH) stores (now owned by Sears and called Sears Hardware stores in some areas) have a complete selection of SAE Grade 5 and 8 fastners in both national course and national fine thread pitch. They have virtually every size that you could need for automotive applications and, even, most sizes needed for HD truck applications.
        • ronnie Robertson # 36786
          My local NAPA has a good assortment *NM*
          • Dale Pearman
            At the Heat Treated Fine Thread Bolt and Nut store!
            Dale.
            • Dale Pearman
              SERIOUSLY
              Look in the Yellow Pages under, "Industrial Fasteners". There is a myiad of fastener suppliers out there with everything under the sun.
              Dale.
                • 43260
                Re: SERIOUSLY
                Dale-----
                The problem is that most suppliers of "industrial fastners" that one might find in the yellow pages of the phone book or other business guide don't sell these fastners in "consumer" or "retail" quantities. One needs to purchase a 50 or 100 size package of all the same size fastner. So, if one needs, say, 4, of a 3/8-24 X 1" cap screw, then one will have to purchase 50 or 100 from an industrial supplier. That will leave one with 46 or 96 in surplus.
                • Dale Pearman
                  I Usually Go
                  the "Request An Engineering Sample" route. That gets me free samples. If that tact doesn't work then the distributor usually will refer you to a retailer. Some Yellow Pages also list retailers.
                  Dale.
                  • Ed Jennings
                    Re: I Usually Go
                    You will find that if the fastner house actually gioves you the wholesale price, a box of 50 or 100 given fastners may cost no more than the handfull you want from a retailer.
                      Re: I Usually Go
                      My local Mom-and-Pop hardware store usually has whatever I need in one of their hundreds of pull-out fastener display drawers - Grade 5, Grade 8, Holokrome Allen capscrews, etc. - they even have LH thread jam-nuts for rod ends. Failing that, the Detroit area has more fastener suppliers than you can count. If you don't have access to any of the above, try AMK Products in Winchester, Virginia, (540) 662-7820, www.amkproducts.com - their catalog is five bucks, but they have every automotive fastener imaginable and they ship the day you order; just fax your order and wait for the mailman - great folks.
                      I also maintain a major inventory of ARP fasteners (the best, period), but those are for non-Corvette projects; 12-point aircraft fasteners don't fly on the judging field
