c1 tank felt size - NCRS Discussion Boards
c1 tank felt size
  • Scott Myers
    c1 tank felt size
    I just purchased the Zip products tank felt, is it the right size
    as recieved or do I need to trim it down. I can not find any specs
    in the AIM and while it seems to fit there is about an 1 inch section
    that seems to not fit at the bottom edge of the cover where there is
    a molded radius that curves to the back. Any suggestions would be appreciated!
    Thanks in advance.
  • Christopher R.
    • March 31, 1975
    • 1599
    Re: c1 tank felt size
    It probably fits. Most any size would. It's nothing but an anti-squeak device. It goes between the tank and where it sits to prevent noise if it were to move. If it prevents the tank from touching the fiberglass when strapped down, it is the right size.
    • Scott Myers
      Chris, I am not referrring to the anti-squeak pads that sit underneath
      the gas tank. I am asking about the Felt that gets glued to the top of the fiberglass tank cover and protects the soft-top from getting scratched.
      It seems slightly oversized and I was wondering if it mattered what size I
      should cut it to, if at all???
