'67 Air Cleaner Silk Screen - NCRS Discussion Boards
  • Richard Pressley
    What is the silk screen on the bottom a '67 air cleaner top supposed to say?
  • William O.
    • April 30, 2001
    • 355
    Re: 67 Corvette with 427
    "Service Insructions"
    REMOVE FILTER FROM THE SCREEN-WASH IN KEROSENE-SQWEEZE
    -DO NOT WRING-DRY COMPLETELY WITH LOW PRESSURE AIR.
    DIP IN 10W30 OIL-CAREFULLY SQUEEZE OUT ALL EXCESS OIL.
    REPLACE FILTER SO THAT TOP AND BOTTOM OF
    SCREEN IS COMPLETELY COVERED ALL AROUND.
    AND A RECTANGLE THAT HAS A "AC" CIRCLE IN THE MIDDLE, THE LEFT SIDE SAYS:
    INSPECT FILTER ELEMENT
    EVERY 12000 MILES.
    MORE OFTEN UNDER
    SERVERE DUST CONDITIONS.
    "UNDER THIS PART SMALL PRINT THAT SAYS" "AC SPARK PLUG".
    ON THE RIGHT SIDE:
    FOR REPLACEMENT
    USE A273C
    FILTER ELEMENT.
    "UNDER THIS SMALL PRINT THAT SAYS" "FLINT MICH."
    • John M.
      • February 1, 1997
      • 52
      Re: '67 Air Cleaner Silk Screen
      Here is a link to a photo of 1967 L-36 427/390 Air Cleaner Silk Screen.
      • Roy Braatz
        My 67 327=350hp top cover in raisd numbers bottom side is
        Service Instructions usa
        --------------------- AC
        service air cleaner breather and A212CW
        CZ crankcase vent valve in accoro filter
        6487699 with owners protection book
        AC filter element are pre-
        oiled for greater capascity
        do not wash or blow with air
        I tryed to lay it out but see that when I post it , that wont work!
        • Richard Pressley
          Is there a difference in the wording of a 327/350 and a 427?
