63 paint detail questions - NCRS Discussion Boards
  • Larry Boden
    Hello All, Just painted the car and I am looking at the door main weatherstrip but first have to sort where the color change between interior and exterior took place. Since I've changed the color inside and out can someone tell me where the colors would overlap. Should the body color come around the inside top of the door and disappear under the weatherstrip? This would leave your interior color, which is different, continuing out of the lower side of the weatherstrip. If so then the sides of the door top should follow the same principle. In addition, as the body color is on the end of the door where should the interior color start. There is an obvious L shaped seam just below the window which would appear to be a good starting point for a interior color change. Thoughts?
    Best Regards Larry Boden
  • Bill W.
    • March 1, 1980
    • 2000
    Re: 63 paint detail questions
    all jambs are body color ....Bill
