C2 Exhaust replacement - NCRS Discussion Boards
  • Michael S.
    • May 31, 2002
    • 91
    I would like to replace the exhaust system on my 67 327/350. Current system seems odd- right and left under car pipes do not match- the right side has "corrugation or ridges" at all of the bends, left has none. Right side seems to jump in size under the passenger seat- left side does not. I believe the swedging from 2 to 2 1/2 takes place at the mainfolds.
    Does this system sound strange ? Any suggestions for as a close to stock system including mufflers ? Aluminum, stainless or standard carbon steel ?
    Any advice is much appreciated.
    Re: C2 Exhaust replacement
    Mike -
    I just put a Paragon complete aluminized system on my '67 327/300, and I'm very pleased with it - not a wrinkle or corrugation in it anywhere, everything fit up very nicely. It comes with regular "saddle" clamps, which aren't correct - I got the "guillotine"-style clamps from LICS for $5.00/pr. (you need 2 pair).
    They also have (by special order) full systems made from plain carbon steel that have the rear sections of exhaust pipe welded to the muffler inlet pipes a la original, but they'll rust in a hurry and you'll have to wait 2-3 weeks to have it made up.
    The original pipes were mandrel-bent (as the Paragon pipes are) and had no wrinkles or corrugations at the bends.
      • 11644
      John,
      Can you compare the Paragon system to one from Corvette Central? Or do you not have any experience with theirs?
      Patrick
        Patrick -
        Don't know who makes CC's system for them, or how it fits - the only one I've worked with is the Paragon package; after dry-fitting it, all I had to do was shorten the right side exhaust pipe (crossmember to muffler inlet) about 3/8" to get zero stress on the rear muffler hanger. Other than that, it fell together very nicely.
          • 11644
          John,
          CC makes their own. I'm not sure how its status is re: flat vs. round pipes, correctness, etc. on midyear pipes. I have one of their systems on Dad's 72 and it fit fine. I was able to install it without difficulty, and that was even before we got the lift.
          Patrick
