C3...Wiper blade - NCRS Discussion Boards
C3...Wiper blade
  • bruce11495
    C3...Wiper blade
    Does anyone know what the correct "wiper blades" are for a 72? How many ribs on the blades? Thx in advance
    • 15601
    Re: C3...Wiper blade *TL*
    I can't remember off the top of my head, but it is spelled out in the Technical Information Manual and Judging Guide.
    • Bernard S.
      • June 30, 1992
      • 56
      Bruce: The wiper blade has a black metal insert to which the rubber is mounted.
      The rubber blade has the following wording just below the metal insert " One or more patents 2543383 2687544 2697241 2766474 2834976 BR 790496 CAN 52.55.58 Pat Prending". Two raised rubber ribs are below the wording on the body of the blade.
        Easy to get confused here with terminology. The term "blades" typically means the blade holder + rubber refill as unit to snap onto the wiper arms. There's a difference in factory original blade holders of the era vs. today's 16-inch functional replacements from Trico (deals with exact geometry of blade holder's upper bridge and black vs. non-blackened finish).
        The same goes for the rubber refills. How is the sidewall of the rubber reinforced now vs. then and what is the color/finish of the metal rails that hold the rubber? If you can find old Trico stock in a ma/pa autoparts store packaged in a cardboard box (red, white & blue with photo of Camaro) under the Trico stock number 41-160, you've most likely stumbled a 'hit' on matching the factory original refills for your blade holders!
