64 coupe wheel cylinder - NCRS Discussion Boards
  • Robert V.
    • July 31, 2000
    • 84
    The passenger side rear wheel cylinder is pitted and I think needs to be replaced. The manual states 1" on passenger side and 1 1/8 of drivers side? When checking for a replacement, some of the books do not list size? What is correct?
    Re: 64 coupe wheel cylinder
    Bob -
    I don't have the '64 Supplement, but the '63 Shop Manual says the rear wheel cylinders are 1.0"; they would NOT be different sizes on each side.
      • 15680
      My'63 AMA specs state 1.1875" front wheel cylinder (1 3/16") and 1" rear wheel cylinder. They are the same as the B-body - full sized pax car.
      You can get the AMA specs for your '64 by calling GM customer service at 800-222-1020 and asking for the restoration package. They'll want your VIN and there is no charge.
      Bendix, Raybestos, and Wagoner show the same sizes in their catalogs.
      • David W.
        • December 1, 1999
        • 272
        Bob-
        If you want to take the safe and easy route, Raybestos makes the wheel cylinders and they are available at NAPA or any good parts store. I put them on my '64 coupe and they are exact replacement. The part # is WC34152 for the fronta and WC13387 on the rears. The difference in size you mention is fronat and rears, not driver's side vs passenger. Good luck.
