63 pilot bushing - NCRS Discussion Boards
63 pilot bushing
  • james cear
    63 pilot bushing
    After speaking with the shop that rebuilt my 63 trans ( Larry Fisher) he is convinced that I unfortunately had a repro pilot bushing installed that was not brass. He said he has had many problems that were attributed to to the trans only to find this problem. I understand that there is a needle bearing bushing available from GM. Is this true, advisable, and if so does anyone know the part number or should I just find a good brass replacment. Thanks
    • 43221
    Re: 63 pilot bushing
    James------
    The needle bearing pilot bushing is GM #14061685. It will work very well providing that your block, bellhousing, and transmission are in acceptable alignment. This bearing is less tolerant of any mis-alignment than the oilite bronze type bushings. If yo do go with a standard bushing, make sure that it's an oilite bronze type bushing as were all original GM bushings. I don't know, for sure, if the current GM replacement bushing, GM #10125896, is an oilite bronze bushing, or not.
    • Clem Z.
      • January 1, 2006
      • 9427
      unless you want to go to the trouble of checking the bore of the bell housing for being true to the crankshaft i would get a bronze pilot bushing.
      • Wayne K.
        • December 1, 1999
        • 1030
        James,
        Would you mind telling us what kind of trouble you were experiencing because of the pilot bearing issue ? Thanks
        • james cear
          Re: Wayne
          Wayne, pls see my post about 2-3 weeks ago where I described the symptoms. JIM
