1965 Coupe 396/425 - NCRS Discussion Boards
1965 Coupe 396/425
  • John Mathieu
    1965 Coupe 396/425
    Hi guys,
    Finally got the clutch and transmission back in the car and had the carburetor rebuilt. Runs great until after about 20 minutes then she won't start again. As a matter of fact, the starter won't even turn. Car cools down for about 5 minutes and bam, starts right up like a champ. Anybody ever experience this?
    Anyone know how to change your email address in your profile? Edit profile doesn't allow the change. Tks in advance.
    John
    jmathieu@allari.com (new email address)w email address)
  • John Mathieu
    Figured out the email challenge. Tks *NM*
    ME>LINKURL>
    • John Mathieu
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: 1965 Coupe 396/425
        check all the wires to the starter for loose connections and if no loose connections try a new solenoid
        • Jack layton #896
          Replace the solenoid spring with the weaker unit.
          • Bill C.
            • December 1, 1991
            • 177
            The GENERAL figured this out a long time ago and offered a "Hard Start Solenoid Spring" which is still available from GM. Don't have a # handy but the guy at the counter will know.......Bill #20328
            • John Mathieu
              Thanks for your response.
              Appears that I have a bad ground connection at the battery which is intensified when the car is hot.
              Have you heard of this before? Is it common?
