1961 crossmember - NCRS Discussion Boards
1961 crossmember
  • Joe D.
    • April 30, 2002
    • 382
    1961 crossmember
    I just had my crossmember disassembled. The part that receives the upper inner shaft for the upper A arm is missing a
    steel bushing, that looks like it is pressed into the crossmember. There is one on each side of the crossmember which the shaft goes into. The old upper inner shaft was spotwelded to a partially broken bushing. Are the steel bushing available? Thanks for the help, Joe
  • Kris Schmalenberg
    Re: 1961 crossmember
    The bushings are available from corvette central. Good luck!
