C-2 A-ARM PAINT - NCRS Discussion Boards
C-2 A-ARM PAINT
  • Stephen L.
    • May 31, 1984
    • 3152
    C-2 A-ARM PAINT
    I am probably #1005 asking this question.......
    What is the correct finish on the A arms of a 67? The judging guide says gloss black while many of the restoration publications say semi-gloss. Mine "appeared" to be semi-gloss before I stripped them. If the frame and most other components are semi-gloss why would the A arms be gloss?
    Misprint in the 67 Judging Guide??
    • 43203
    Re: C-2 A-ARM PAINT
    Steve----
    The a-arms were not painted the same as the frame and have a different degree of gloss. That's because the frame was not originally painted, at all. It was coated with an asphaltic coating. This coating had a degree of gloss APPROXIMATELY similar to semi-gloss paint.
    The a-arms were dip painted with actual paint. They were semi-gloss, but tended to the glossy side of semi-gloss. SERVICE replacements, when they were available, were often painted with a high gloss black paint.
    • Gene M.
      • April 1, 1985
      • 4232
      Re: C-2 A-ARM PAINT
      Steve, Most all the black chassis components are a semi gloss (when new). But age takes it toll on original appearances. The A arms are, when new, of a higher gloss than the other parts of the chassis. Not a lot glossyer but they did shine more. The judging guide just attempts to make the difference known.
      • Stephen L.
        • May 31, 1984
        • 3152
        Re: C-2 A-ARM PAINT Thanks for the input
        Thanks Joe & Gene for the input. I'll paint 'em gloss! and mark up my restoration books for future reference
