I was setting the timing on my small block and did not have a dial back light. I wanted to set it at 35 total and planed on marking off three ten degree marks (using the 0-10 distance from the timing mark) and using that mark to set it at an additional 5 degrees, when being both fat and lazy forced me to think up something easier then laying on the ground and reaching under the car. It dawned on me that the cylinders are 45 degrees apart from each other and I could hook the light to the #8 wire and set the timing at 10 degrees after on # 8 resulting in #1 being 35.
Is this an old trick that no one ever told me?
Tom
Tom
