Correct color of upper/lower control arms - NCRS Discussion Boards
+ More Options
Posts
  • Ralph A.
    • May 31, 2002
    • 236
    Started my 1971 suspension restoration.
    Judging manual indicates these are semi gloss black. I just removed mine from the suspension and I can not find any "paint" on any of the 4 pieces. I thought these were original but now I am confused. Can someone shed some light?
    Also need to change the upper ball joints. I can drill out the rivits but what do I use to replace them. I have the new rivits. DO I just beat them until tight?
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Eric Fairclough
    Re: Correct color of upper/lower control arms
    My 72 control arms are semi gloss and it is all original. You have to take the control arms to the machine shop and get the pressed in. Hope this helps. Eric
    • Ralph A.
      • May 31, 2002
      • 236
      Thanks Eric, I just found it unusual that there was no paint on my arms.
      Do you know what type of "pressed in" tool they use?
      Ralph Adams
      NCRS: 38137 LA: 112
      Slidell, LA 70461
      • Eric Fairclough
        I'am not sure exactally what type of tool the use. I just assumed it was a machine shop floor press. Eric
          • 43263
          Ralph-----
          The front a-arms were originally dip-painted a semi-gloss black which tended to the glossy side. Very often, the outer 4 inches, or so, of the upper arms were unpainted. I've never seen a set of these arms which were totally unpainted, but I wouldn't rule it out as a possibility.
          SERVICE ball joints are installed using the nuts and bolts which are supplied with the SERVICE ball joints. If you wish to re-rivet the joints, it's best to send the arms to a specialist like Bair's Corvette in Linesville, PA. Your average machine shop will not be able to re-rivet them and there is no way that you can do it yourself without special tooling. Machine shops may be able to replace the bushings for you, though, if you are unable to do so yourself.
          • Thad L.
            • April 30, 1999
            • 168
            Ralph, a good rule of thumb is that your control arms should be a little glossier than the frame. Frame is usually flat black and the arms a just a tad more shinny. Thad
            • Ralph A.
              • May 31, 2002
              • 236
              Thanks for the info. My arms are fairly rusted and I worked on them last night.
              Still did not find any good evidence of paint. I plan to paint them just the same.
              I had to change the ball joints as the rubber is dry rot and leaking. My mechanic has some machine tools (prior life) available but he has never put in rivits. He was just asking for advice. We will try with a hammer chissel and see if that works, if not we may have to send them off.
              I have no problems pressing in the bushings.
              Ralph Adams
              NCRS: 38137 LA: 112
              Slidell, LA 70461
