Bellhousing Casting #3899621 - NCRS Discussion Boards
  • Tim anderson
    What's the application for bellhousing Casting #3899621
    • 43236
    Re: Bellhousing Casting #3899621
    Tim-----
    The GM #3899621 bellhousing has very wide application relative to Corvettes and most other Chevrolets of the 67-82 period. It was used on 67-68 Corvettes with 427 (except L-88) and virtually all 69-81 Corvettes, except L-88/ZL-1 and ZR-1.
    The GM #3899621 bellhousing is designed for use with a 14" flywheel used with an 11" clutch. It is, by far, the most common bellhousing used for Chevrolets with 14" flywheels and 11" clutches.
    • Tim anderson
      Re: Thanks Joe *NM*
