C2 Muncie Close Ratio 4 spd. Diagnosis - NCRS Discussion Boards
  • Wayne K.
    • December 1, 1999
    • 1030
    I've owned my 67 L79 for 7 years and since I've owned it I've had this issue with the transmission and would like some opinions.
    The issue is when I want to shift the transmission fast it clashes the gears. This only happens on upshifts. The clutch and linkage seem to be fine and if I use a slight hesitation between upshifts it isn't a problem. It hasn't gotten any worse over the past 15,000 miles but I know this shouldn't be and would like to know what the problem is. Thanks in advance for sharing your thoughts.
  • Scott Marzahl
    Re: C2 Muncie Close Ratio 4 spd. Diagnosis
    Sounds like it needs new Synchro rings.
    • Bill Clupper
      Second the motion, a new set of brass blocking rings (suncro rings) should do it. While it's apart, new seals, bushings and misc. parts should get you back up to snuff.
