Headlights For C2 - NCRS Discussion Boards
Headlights For C2
  • John Lokay
    Headlights For C2
    I was following my wife home last night in my 66' coupe and when we got home she told me my headlights were dim, one side more than the other. Is this a function of the headlight bulbs going bad, dirty contacts on the back of the headlight bulbs, or weak current flow to the headlights? What should I do to address the problem? The amp gauge during the ride home showed no discharge as the needle stayed in the middle. Thanks
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Headlights For C2
    If your ground connection is poor it can cause your lights to be dim. You may want to check the ground wires. Clean all the connections.
    • Donald O.
      • May 31, 1990
      • 1591
      John,
      If you are using T-3 bulbs replace them with new halogens. Keep the T-3s for any judging though. My $02.
      Don
