C2 Frame Number - NCRS Discussion Boards
C2 Frame Number
  • Michael S.
    • May 31, 2002
    • 91
    C2 Frame Number
    I am in the process of verifying numbers and codes on my 1967 convertible. Where can I find the frame number- I believe it is passenger side main frame rail toward the rear- but where- inboard, outboard, do I need to remove anything ?
    thanks
    • 43241
    Re: C2 Frame Number
    Mike-----
    It's on the driver's side frame rail. It's on the TOP surface of the frame rail APPROXIMATELY between the welded-on crossmember behind the differential crossmember and the #4 body mount. It is difficult to see inasmuch as the body is very close to the frame at this point. You will need to thoroughly clean the area with a small brush and then use a mirror to see it. Even then, it will be difficult. It was DESIGNED to be difficult to access.
    • Stephen L.
      • May 31, 1984
      • 3159
      Re: C2 Frame Number
      Mike,
      The frame is marked/stamped in 2 locations with the serial# on my 67.
      The first location is under the drivers door about 12 inches ahead of the #3 body mount location (literally impossible to see with the body on). The second location is adjacent and just forward of the left side #4 body mount. As Joe said its a tight squeeze to see it. Good luck.
      Steve
      • Michael S.
        • May 31, 2002
        • 91
        Re: C2 Frame Number
        Thanks for the help guys. Many more questions to come.
