C1 1960 Window Crank Spring orientation - NCRS Discussion Boards
  • Rick Coleman
    The spring that goes between the door and door panel on my 60 is tapered. It's not clear from the AIM, etc. as to whether the large end goes against the door or against the door panel. It appears that if the small end goes against the door panel it will slightly protrude through the window crank hole.
    Can anyone advise?
    thanks, Rick
  • Ed Jennings
    Re: C1 1960 Window Crank Spring orientation
    The way I read the AIM, the small end goes toward the door and the large end presses against the metal on teh door panel. The hole in the cardboard should be slightly larger so the metal is pressed against the window crank.
    • Rick Coleman
      Bingo! That's better. Thanks! *NM*
      • Bob Malone #35242
        What about the Rubber Seal?
        DAMN! I got the spring backwards! Am I correct in that the sponge rubber seal goes between the door and door panel with the cupped out side facing outboard?
        • Ed Jennings
          Re: What about the Rubber Seal?
          Bob, I don't have an AIM to look at right now, but I THINK the seal goes between the door and the spring, cup toward teh door panel. I'll try to remember to look tonight.
          • Rick Coleman
            If I'm looking at the AIM correctly, the cup (open side) faces against the door. Sure hope so... Since I had to take the panels off to correct the spring orientation. Rick
            • Ed Jennings
              Rick, Yes that appears to be correct; the "cup" faces outboard.
