Flywheel - NCRS Discussion Boards
Flywheel
    • December 1, 1999
    • 97
    Flywheel
    Can someone identify and provide the application of a flywheel with the casting number "14091559N". It bolts up to a late model Chevy crankshaft with a one piece rear main seal. This FW has the ring gear teeth for the starter on the transmission side rather than the engine side. TIA, John.
    • 43221
    Re: Flywheel
    John-----
    What's the diameter of this flywheel or how many teeth does it have on the ring gear?
      • December 1, 1999
      • 97
      Re: Flywheel
      Joe; The flywheel has 168 teeth, 14-3/8 across the teeth and 13-7/16 across the plate surface. An 11" clutch fits nicely.
        • 43221
        Re: Flywheel
        John-----
        Well, about all that I can tell you is that this flywheel has no Corvette application. All Corvette (and Camaro) one piece rear seal engines used flywheels of 12-3/4" and 153 tooth ring gear.
        If it were not for the strange configuration of the ring gear on the rear of the flywheel, I'd say that this was a GM PART #10105832 flywheel. This is the 14" flywheel for one piece seal applications. However, this flywheel has the conventional ring gear orientation.
          • December 1, 1999
          • 97
          Re: Flywheel
          Thanks for the info Joe. I guess I will pass on this one.
