Black oxide finish - NCRS Discussion Boards
Black oxide finish
  • Richard Pressley
    Black oxide finish
    During a recent judging, several bolts/screws were deducted because they were painted black instead of being black oxide. How can I correct the finish on these pieces?
  • Larry Gawron
    Re: Black oxide finish
    I live in the Atlanta area and recently took all my black oxide fasteners and parts to a local company called Kirk-Rudy. They are a manufacturing company that also does black oxide plating.
    Here is their website: http://www.kirkrudy.com/services.htm
    • Gary B.
      • February 1, 1997
      • 7024
      Black oxide vs. black phosphate
      Richard,
      Do you for certain that the bolts/screws should have been black oxide and not black phosphate? These two finishes are not the same. Many platers can do black oxide, which is typically glossier than either black phosphate or flat black paint.
      Gary
      • Stephen L.
        • May 31, 1984
        • 3158
        Re: Black oxide vs. black phosphate
        Gary,
        I am at the point of plating some "black" bolts such as the rear spring 6" bolts on my C2 67. Which is correct? Black oxide or black phosphate? The bolts are already black but are "shiny" because I cleaned them on a wire wheel buffer so I really can't tell the original lustre. I have a bunch of bolts that need to be "blackened"
        Steve
