Windshield Washer Pump - NCRS Discussion Boards
  • Jerry Coia
    I've installed a new pump in my 1963 roadster and am looking for ways to get it "primed". Any ideas?
    Jerry
  • Bill Clupper
    Re: Windshield Washer Pump
    Use a turkey baster, fill it with washer fluid and use it to force fluid from the reservoir lint thru the pump and nozzles.
    • Joe C.
      • August 31, 1999
      • 4598
      Jerry:
      If your pump is working properly, and the valve assembly, and bellows are good, then it should take 3 to 4 cycles of the pump (each cycle consisting of maybe 6 strokes) for the fluid to be drawn through and out the nozzles. If not, then go after an internal problem/blockage.
      Joe
