Avalible piston sizes for 350 - NCRS Discussion Boards
  • tim anderson
    What are ALL the piston sizes avalible for rebuilding 350's. And from whom? (ie dealer, trw....)
    And were not talking about strokers or anything fancy.
    • 43237
    Re: Avalible piston sizes for 350
    Tim------
    standard, +.020", +.030" (most common), +.040", +.060"
    I don't know of any others, but there may be some. GM also offers pistons in +.001", but this is, basically, for standard bore engines which just need a light honing to clean them up or for "high standard" standard bore engines.
    The above piston oversizes are available from Federal-Mogul/Sealed Power/TRW (all the same company now). All of the above sizes are available in cast and hypereutectic cast. I don't know, at the moment, if all are available in forged.
    Any automotive supply house should be able to order them for you.
    • Michael R.
      • April 1, 2000
      • 68
      Joe,
      can the original 11 to 1 L46 pistons still be ordered? If so, are they forged or cast only?
      --Mike
        • 43237
        Mike-----
        The 1969-70 L-46 and 1970 LT-1 pistons are no longer available from GM. However, reasonably close replacement pistons can be ordered from Federal-Mogul/TRW/Speed-Pro under their part number L2304F. These pistons are forged, as original, and will produce a compression ratio of about 10.6:1.
        A better choice would be Keith Black hypereurectic pistons, but that's another story.
          • 11651
          Don't go there, Joe.
          Patrick
          • Tim anderson
            Re: Thanks! *NM*
