Choke Tube - 1964 365hp - NCRS Discussion Boards
  • Dino L.
    • February 1, 1996
    • 694
    How does the chrome choke tube fit into the exhaust manifold. My manifold has a tube about a 1/4" below the surface that exits the bottom of the manifold, the chrome tube will not fit in either the larger hole on the surface that the through hole tube is pressed into or the through tube inner ID.? Won't this cause a rattle, and how does it seal? Can someone tell me what I have ? Thanks
    Dino Lanno
  • Bill W.
    • November 1, 1977
    • 402
    Re: Choke Tube - 1964 365hp
    Mornin' Dino,
    Your chrome plated tube should fit (tightly) into the 1/4" recess you describe. You may need to file a slight bevel into the leading edge to help start it. It's only seal is the tight fit. Check the hot air tube in the manifold for "rust through", and replace if necessary, other wise you will gum up your choke. Bill
