Wheel Alignment Wizard - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    I'd like to know if any of you folks can recommend a top notch alignment shop (preferrably a Corvette specialty shop) in central New Joisy. Best case scenario is a place where there is a seasoned technician on hand who can still see. Of course, the main issue is proper handling of the rear toe shims.
    Any (sound) advice is much appreciated.
    Joe
  • Jeff Debs
    Re: Wheel Alignment Wizard
    Hi Joe,
    The only referral I can give is for a good alignment shop in South Jersey called Jack's alignment. It's a father and son run shop and I think they have been doing alignments for something like 25 to 30 years, maybe more. I've used them twice for my '63 which included the initial "set-up" once the body-off was completed and once again after my rear was removed and rebuilt for the 2nd time.
    The shop is located near Medford, N.J.
    Like I said, I've used them twice and have been very satisfied.
    If you decide to contact them, e-mail me and I'll find their # for you.
    Good Luck,
    JD
    • Al S.
      • June 30, 2002
      • 73
      Try Corvette Paramedics they are in Mount Holly. I haven't had any work done there personally, but I have seen his shop and some of his finished work and it's top notch. He's got a guy that does all his alignments on his restorations who's not too far from him, and he claims he can align anything from a golf cart to a farm tractor. His name is Ed (609)265-2702. Give him a call. He started out as a machinist and blossomed out from there over the years. He's quite a perfectionist.
      '72 Top Flight Coupe
      • Joe C.
        • August 31, 1999
        • 4598
        Thanks Al And Jeff *NM*
