More Gas Tank Woes - NCRS Discussion Boards
More Gas Tank Woes
  • Scott Myers
    More Gas Tank Woes
    c1-1960 Exasperated!!!
    Ok, I have put my new quanta tank in place with the metal straps connected
    to the front with thier pins in the proper place. Now after much NUDGING
    I still seem unable to get the bolt end of the strap down into the
    rear area between the tank and the fiberglass, the fit is to tight to put
    anything in thier. Any tips on coaxing the strap into place would be
    greatly appreciated!!!!
    I remeber Al Ceiler saying he had to use longer bolts initally to reach
    the nut plates on the underside then replace with shorter bolts. While
    this may seem to work, I don't think I can even get a bolt in there.
    Yes it is the right year tank according to ZIP. Are there do's and dont's
    about prying, nudging, malleting etc.. that I should know about.
    HELP!!!
  • Scott Myers
    Re: More Gas Tank Woes
    OK, I see there have been 50 viewing's of this post, doesn't anyone
    have some advice for me. I am going to very gently try a pry-bar
    tonight when I get home from work. Did I mention I am a novice here!!!?
    Thanks in advance for any help.
      • December 1, 1999
      • 97
      Scott - I also just installed a new "Quanta" tank in my '61. Some time back someone said that the joint between the top and the bottom sticks out farther on the new tank than on the old. I got in there with a bar and gently bent the edge more to provide clearance for the straps and bolts. I hope that I didn't warp it enough to cause a leak. Will find out when I put some fuel in it. Good luck, John.
      • Scott Myers
        Thanks John, that was what I was afarid of. let me know if You have
        a leak, meanwhile I will try to be very carefull.
        • Al C.
          • July 31, 1999
          • 274
          Scott,
          I also had the problem and should have mentioned it in my earlier response. The new tank was a b---h to get seated in the compartment, and I had to push and pry and curse and hope I didn't do damage.
          Especially, the protruding seams needed coercion.
          Keep at it!
          ... Al '58 #378 245hp NCRS SACC
