70 454 Q-Jet heat insulator - NCRS Discussion Boards
  • Chris H.
    • April 1, 2000
    • 837
    I'm going to be removing the non original California heat sheild. I have a new carb/manifold gasket, but also think I need a "heat insulator".
    Does the heat insulator go between the gasket and the carb? What is it made out of?
    Thanks, Chris
    • 43221
    Re: 70 454 Q-Jet heat insulator
    Chris-----
    No heat insulator was used on non-California 1970 LS-5. There was just a gasket of GM #3967470. This gasket had one large opening rather than the 4 venturi holes used on 68-69 Q-Jet applications. The GM #3967470 is discontinued, but available in reproduction.
    • Chris H.
      • April 1, 2000
      • 837
      Joe, I guess I'm confused. The JG says all 454s had a "heat insulator". The 49 state cars had one that is 1/16th inches thick, and the California motor had one that is 3/16th inches thick.
      Is the insulator also the gasket?
      Thanks, Chris
        • 43221
        Chris-----
        The judging guide may call it a "heat insulator", but that's not what GM called it and that's not what it's called in the automotive vernacular. ALL 1970 non-California applications used a simple gasket. Now, as I recall, this gasket MAY have been made of an asbestos-steel composition material and, in any event, undoubtedly had some insulating properties, but it was not an insulator, per se. I've got several of these in my collection [none for sale], but I'm not prepared to retrieve them to inspect for exact configuration.
